Now here is a question for all you turbo junkys......
From my understand the compression on a stock turbo with a P90 head and dished pistons is 7.8:1 correct ( sorry if im a little off thats from memory )
When you mix flat top pistons with a p79 head produces an estimated compression ratio of 8.8:1.....
now here is the question...
What if you were to take flat top pistons and a P79 and installed them on a turbo for the compression ratio of 8.8 : 1....this would increase your torque over what you used to have because of the raised CR ( right? ) but still be a low enough compression that with an intercooler could produced the high end power of a turbo motor? now i dont know if this has been done and its just a theory on my part. Let me know what you think....
So basically im saying could you use a P79 cycl head and flat-top pistons for a turbo and produce MORE power ( torque and maybe HP ) than a stock turbo?
Matt
https://www.classiczcars.com/forums/topic/1611-question-for-turbo-junkys/
