Rear wheel bearing preload
240ZMan
and what is the significance of this B mark? I haven't seen it referenced in my Clymer manual, and haven't really looked at the haynes yet, but I too am in the disassembly stage right now, and trying to save any future headaches.
The letter marking (A, B, C) on the outside of the hub needs to match the letter marking on the "distance piece" that goes inside the hub between the inner and outer wheel bearings. There are other threads that have more detail on this:
http://www.classiczcars.com/forums/showthread.php?t=14450&highlight=distance+piece
I decided to take my rear assembly to a shop to pull the stub axles and bearings so I wouldn't mess them up without a press to and slide hammer to disassemble them. The bozo at the shop stripped the stub axles, where that crimped nut is. I don't know how, but he stripped about 1/2" of thread on one and 3/4" on the other.
Good thing I have another set on the car right now. Like they always say, if you want it done right, do it yourself. I am so po'd right now, plus they still charged me $40!!!!
I decided to replace the rear wheel bearings on my 78 280 in an attempt to solve a grinding noise - bingo, one of the bearings nearly locks up when I test it. I'm fairly certain that rust flakes caused the bearings to go bad as the cavity between the inner and outer bearings had a small pile of rust in it. So: how should I prevent rust from forming in there again before I reassemble everything? I have some POR but I can't find anything about high temp situations. I'm also thinking of just filling up the entire cavity with grease to match the new grease in the bearings. Any thoughts? Also, any thoughts about using the electrolitic rust removal process to clean up some of the pieces (axle stub, intermediate piece btwn half-shaft and stub nut)?
Cheers!
  • Who's Online   1 Member, 0 Anonymous, 502 Guests (See full list)
