I saw a buff ball (made of sponge???) at the Murrays. It looks like it would last about 2 minutes, but it was $24!!?? Is that right? I thought a buff ball was made of better 'cloth' stuff.
Local K-Mart had Never-dull. I'll go get some, thx. Maybe I could rig up a thing to go on the drill. Door sill plates need help too. Maybe other stuff...
SJGREEN71-
I tried some NevrDull on the bumper and it didn't do diddly. the AL polish did some cleaning, but the underlying chrome is still (old). I concluded that the Nevr Dull is for maintenence or light polishing only, being just a soft cloth soaked with a petroleum product for lubrication. I'd take the can of NevrDull to a show to touch up or a quick shine. Just pull off a bit & rub. No second rag needed. If you have something with a heavy layer of (patina), then you'll need something like a paste or a chemical. I used Eagle One Aluminum paste polish on the 280ZX wheels, and it shined those up really fast. I just gotta get into the nooks by the air valve to get it clean too.
thx
My friend told me that he saw polishing chrome on "Myth busters", using Coca Cola rubbed on with al-foil. Kinda weird I know, but if you're going to fork out to get it rechromed you might as well try that before you do. If it stuffs up there's no great loss.
As Aaron said, If the chome is pitted, you'll only polish off the chrome you have left! Although you can get bare steel to shine, it doesn't last very long :)
Exhaust gases builds a very tough patina. I cut this off from my new chrome with "Mothers" brand "Paint Cleaner". It works better than any polish I've used to date.
  • 3 weeks later...
well, steal wool will clean it up, use brasso as a lube. This will actually further damage the surface, although it will look better.
HOWEVER, it will rust up/deteriorate when exposed to moisture. Face it, if pitted, the chrome is gone. time to have a redo for the long term
