I just set up the gallery slideshows to work in a full-screen mode. This should make the slideshows better to watch. They used to show our header across on every refresh which required a user to scroll down. Now, the slideshow will start by eliminating our header and only showing the images....
Anyway, if you want to try this, go open the photo gallery, pick a gallery of some kind (for instance, one of our events). Make sure you pick one image and then select the "slideshow" option in the upper right corner of the screen.
-- Mike
Cool Mike. I tried it with my gallery and it worked good. My gallery was set to most active (so images were slightly random), but I think if it were set too "earliest to latest" it would actualy show the progress in my rebuild.
Thanks for you efforts.
Recently Browsing 0
