This might work for you,
http://www.arizonazcar.com/inject.html
"1 inch aluminum throttle body spacer to adapt the LARGER 240SX butterfly onto the 1975-1983 Datsun 280Z, 280ZX stock EFI manifold. Includes the longer bolts required. Can be drilled for additional injector, available in red anodized or plain aluminum
$36 each"
You might want to consider upgrading some other things, as you only get improved performance ( if that's you goal) through equal intake and exhaust.
That means if you are using a bigger TB for more flow, your intake (air cleaner stuff) and exhaust should be bigger(if necessary) to match.
thx
