Would someone with a Factory Service Manual for the Euro Spec. DATSUN 240-Z's please Post the specifications for the OEM springs. The Factory Service Manual should list in the Service Data and Specifications at the end of the Front/Rear Suspension Sections: Wire Diameter Coil Diameter Coil Turns Coil Effective Turns Free Length Installed height/load Spring Constant
