Ignition coil wires
78 280zcar
Mine has a black with white stripe wire and a blue wire. Thanks
I'd forgotten that I have a Haynes manual that contains a 280Z wiring diagram. It's really hard to see without a magnifying glass but it does show a blue (L) wire that goes to the resistor and then continues on to the negative terminal.
which brings me to another question. Is there a balast resister on this type of ignition. I know the 75-77 have them but it says that there is one on mine in the chilton manual wiring diagram but I cant find one anywhere in the engine bay :ermm: . HELP. I just bought a Crane fireball ignition coil and it came with a balast resister and I dont know if I have to hook the resister up or not. Thanks in advance.
