Posted June 16, 200519 yr comment_127634 I looked through the Microfiche CD, and I didn't see any pictures of the panels under the dash, kickpanels, or whatever is under there. I know there is supposed to be a panel on the side where the fusepanel is; which is one thing I probably need to get. I only have one piece with the curved end (looks like a ski) that goes along the bottom edge of the dash.Does anybody know what it's called on the Microfiche CD, or which screen to look at, or even where one might order kick panels?thx Link to comment https://www.classiczcars.com/forums/topic/16274-underdash-panels/ Share on other sites More sharing options...
June 16, 200519 yr comment_127639 Tomohawk, How about giving Victoria British or Motorsport Auto a call. They have this sort of stuff and its worth your while to get their cataloges. The cataloges provide you with pretty good visual references too. Link to comment https://www.classiczcars.com/forums/topic/16274-underdash-panels/#findComment-127639 Share on other sites More sharing options...
June 16, 200519 yr comment_127646 Check the classifieds. Lots of us advertise extra parts. I've parted several 280's and have more parts than I'll ever need. Link to comment https://www.classiczcars.com/forums/topic/16274-underdash-panels/#findComment-127646 Share on other sites More sharing options...
June 17, 200519 yr Author comment_127667 The problem is I wouldn't know which panels I would need. I checked both VB and MSA catalogs, and the only panels or stuff the have are for doors, headliner, sunvisor, and rear trim panels.thx Link to comment https://www.classiczcars.com/forums/topic/16274-underdash-panels/#findComment-127667 Share on other sites More sharing options...
June 17, 200519 yr comment_127669 TomoHawk,Look for the panels in the 77-78, I am out of town at the moment, but when I get back(sundayPM/ Monday AM), I will try to find the PNs if you havent by then-I'll even take pictures if that would help.Will Link to comment https://www.classiczcars.com/forums/topic/16274-underdash-panels/#findComment-127669 Share on other sites More sharing options...
June 17, 200519 yr Author comment_127671 Will-Thanks, but all I need to know what is how many panels there are supposed to be in there. A diagram would be enough. I could track down the part #s myself.thx Link to comment https://www.classiczcars.com/forums/topic/16274-underdash-panels/#findComment-127671 Share on other sites More sharing options...
June 17, 200519 yr comment_127687 I see four in my car. One over the ECU on the drivers side, one directly below the dash from the door to the console (the hood release lever and vent knob go through that one), the one you mention on the right side below the glove compartment, and the one over the fuse box (made from fibreboard not plastic like the ohters). There are also two plastic panels where the carpet meets the firewall in either footwell. Link to comment https://www.classiczcars.com/forums/topic/16274-underdash-panels/#findComment-127687 Share on other sites More sharing options...
June 17, 200519 yr Author comment_127689 Probably the only one I would need to get is the one over the fuse panel. Link to comment https://www.classiczcars.com/forums/topic/16274-underdash-panels/#findComment-127689 Share on other sites More sharing options...
June 17, 200519 yr comment_127690 I may have one. I still have a box of stuff I haven't opened since we moved. It might be for the 810 but if it's a Z panel, it's yours if you want it. Link to comment https://www.classiczcars.com/forums/topic/16274-underdash-panels/#findComment-127690 Share on other sites More sharing options...
July 18, 200519 yr Author comment_131069 I ordered a 'kickpanel from Zspecialties. he tells me the only other pieces down there are the one accress the firewall to cover the wires, and the 'ski' piece aling the right front bottom.thx Link to comment https://www.classiczcars.com/forums/topic/16274-underdash-panels/#findComment-131069 Share on other sites More sharing options...
