Part Swaping
blackjack
Not sure about the radiator. The booster does...I think. Seems like some people use them when they convert to the ZX rear disc brakes. So unless you are using the rear brakes Im not sure what benefit you will get from it. It may be too much for your stock brakes. Im sure there are people on here who know better than I do though.
280zx radiator is taller than 240z item but can fit as long as you don't mind having it hanging down lower than the front radiator support panel where it is theoretically quite vulnerable to damage. You will also need to use the 280zx hoses.
hope it helps
Andrew
The radiator hangs about 1.5 inches. Lowest thing in font of the tyres, but still higher than the subframe. So you could bottom it out on a gutter if you aren't carefull. I've had no problems though.
Rear brakes will adapt but you need the hard to find adapter plates. Search for R30 Skyline in these forums and there is a part number somewhere. The front calipers can be used with 300zx discs for a vented disk setup.
The Diff can be used.
The electric mirrors will fit, but the curve where it meets the door is slightly different and can be seen at close distances.
Have fun with it. The power gain with the L28 is good.
  • Who's Online   1 Member, 1 Anonymous, 654 Guests (See full list)
