Re; 2 piece wheels
dat260
Hi guys,
What is the difference between 2 piece and 3 piece wheels. I know with the 3 piece wheel you can exchange the two shells (inner/outer) to get different widths. Can a 2 piece wheels have its shells interchange for different widths also?
Regards, Ari
A two piece rim has a removable center on a static rim width that would allow you to install a different lug pattern center or change the offset of the wheel by changing the offset of the center section that is installed onto that wheel.
A three piece is as described above, allowing you to change the width of the rim as well as the center section.
  • 1 month later...
  • Who's Online   0 Members, 0 Anonymous, 988 Guests (See full list)
