I did a tune up - valve adjustment, new plugs - this weekend and had no idea how much she needed one! The Seat-o-the-pants dyno really felt the difference. IF it's been a while, tune her up. Certainly your car deserves a new set of NGK BP6ES's
https://www.classiczcars.com/forums/topic/16312-dont-forget-to-tune-up/
What is involved with the valve ajustment as far as symptoms of the car needing one? My valves make no noise so i'm assuming that they don't need one, correct?
I still don't feel the car is where it should be on power so i'm trying to explore all options... I've done everything in a "Tune up" sense except for ajusting the valves.
Valves that are adjusted too tight don't make noise, but affect power output of the engine.
The Slide Show linked below is a good introduction to adjusting valves on an L6 engine
http://www.picturetrail.com/gallery/view?p=999&gid=1803105&uid=786489
Good link Carl! I definately bookmarked that one! :cheeky:
