Recently Browsing 0
I've got my rear struts totally disassembled to do a rear 280zx brake conversion, and have all the necessary parts, but am trying to figure out how to remove the drum brake backing plate and dust shield from the strut tube assemblies. Do I just unbolt the 4 center bolts, unbolt the 2 10mm bolts holding the brake assembly at the bottom and cut off the 2 welded rivets at the top to remove them? or is there more? thanks!
(every brake conversion thread seems to assume this portion is obvious.)
https://www.classiczcars.com/forums/topic/16324-rear-disc-conversion-how-to-remove-backing-plate/Share on other sites
