Posted June 23, 200519 yr comment_128347 I need a little help. I have a series 1 made in 1/71 and have the splash pan, but need the original machine screws which have 5mm shafts, 1.0 pitch, and 8mm head. There are nine screws. Anyone have a spare set they are willing to sell? It's the little stuff thats a bear to find. Thanks for any help.DanOriginal owner, 240Zhls30-20419IZCC# 12324 Link to comment https://www.classiczcars.com/forums/topic/16347-splash-pan-machine-screws/ Share on other sites More sharing options...
June 23, 200519 yr comment_128349 I have some on my 75 you can have. Will you be at the next meeting?Robert Link to comment https://www.classiczcars.com/forums/topic/16347-splash-pan-machine-screws/#findComment-128349 Share on other sites More sharing options...
June 23, 200519 yr Author comment_128354 Hey RobertNot crazy, just addicted. I hope to finally make a meeting. I'll let you know. I may be wrong, but the screws for a 280 splash pan I believe are 6mm with a 10mm head.for some reason, they changed sizes, but I could be wrong. I would certainly like to see what you have though.Dan Link to comment https://www.classiczcars.com/forums/topic/16347-splash-pan-machine-screws/#findComment-128354 Share on other sites More sharing options...
June 24, 200519 yr comment_128361 Hello DanWhat you say is interesting here re the change in size of the machine screws. I also have a splash pan and the screws in the body of the car itself seem to be M5 whereas the screws which go into the front cross-member appear to be M6.What do these screws look like for originality purposes? Do they have a cross in the head to take a phillips head screwdriver or are they bolts with the 4 stamped in the head?Maybe you could find a substitute from Nissan to use. Look around the front fender attachment/apron attachment area and you may be able to find something which you could order new from your local NIssan?If you could let me know what the screws look like it would be appreciated.ThanksJoseph Link to comment https://www.classiczcars.com/forums/topic/16347-splash-pan-machine-screws/#findComment-128361 Share on other sites More sharing options...
June 24, 200519 yr comment_128388 Just giving you a hard time. I understand the quest for those elusive parts, I did a lot of seaching for 1973 Trans Am parts at one time.I just checked and you are correct, mine are 10mm. I'll keep my eyes peeled for you though.Robert Link to comment https://www.classiczcars.com/forums/topic/16347-splash-pan-machine-screws/#findComment-128388 Share on other sites More sharing options...
June 24, 200519 yr Author comment_128391 Hi Joseph,Sorry I didn't see your reply sooner. I am certain the early 240 had 5mm shafts and 8mm wrench heads. I really haven't seen those, but the 280 machine screws have a hex head with phillips cross slot, and the finish appears to be a clear or silver cad plate. I am assuming that those for the early 240 are very similar. I've checked with nissan and they have not found any similar in that size. They also have a flat washer that is permanently attached , or fender washer. If I have any success, I will get back to this thread.Dan Link to comment https://www.classiczcars.com/forums/topic/16347-splash-pan-machine-screws/#findComment-128391 Share on other sites More sharing options...
June 24, 200519 yr comment_128425 I hope you don't mind me asking a related question. I have an original 72z that did not have a splash guard. Were they available on the earller cars only or was there a reason they were not installed on all cars. My car was an automatic if that makes a difference.ThanksBob M Link to comment https://www.classiczcars.com/forums/topic/16347-splash-pan-machine-screws/#findComment-128425 Share on other sites More sharing options...
June 25, 200519 yr Author comment_128455 Hi Bob M,I'll probably get slammed by someone with more knowledge, but, for early 69, 70, & 71 z's, only a few were delivery in North America with splash pans. The vast majority came without pans and rad. fan shrouds. I believe, when A/C was factory installed in 73 cars, fan shrouds and splash pans were somewhat standard, for better engine cooling air flow control. There is probably more accurate info if you check out the search function for past threads. Hope that helps.Dan Link to comment https://www.classiczcars.com/forums/topic/16347-splash-pan-machine-screws/#findComment-128455 Share on other sites More sharing options...
August 13, 200519 yr comment_134026 bob m said: I hope you don't mind me asking a related question. I have an original 72z that did not have a splash guard. Were they available on the earller cars only or was there a reason they were not installed on all cars. My car was an automatic if that makes a difference.ThanksBob MHi Bob,I own 2 '73 240's, 1 4spd and 1 AT. Both have a splash pan with the 8mm head. I am missing many of the screws and all but one sheared off while removing to do suspension/steering work. I don't really have a point to all of this, but I thought you might like to know (late as it is). Link to comment https://www.classiczcars.com/forums/topic/16347-splash-pan-machine-screws/#findComment-134026 Share on other sites More sharing options...
August 13, 200519 yr comment_134047 Believe it or not, your local ACE hardware store may have what you need. Like John Madden says, ACE is the place. They have a real good selection of metric and stainless metric hardware, as well as metric threaded rod. If there is one near you, check it out when you determine the correct size y'all need. Link to comment https://www.classiczcars.com/forums/topic/16347-splash-pan-machine-screws/#findComment-134047 Share on other sites More sharing options...
