Posted June 27, 200519 yr comment_128701 I've narrowed my starting problem down to the starter/solenoid not getting power. (after installing a new starter, batt. cables, ignition switch). I know the negative batt cable grounds on the starter and the positive batt. cable goes to the starter lead. My question is which wire goes to the lead on the starter solenoid to give it power. There is a thick harness on the frame rail with a line coming from it that is going to the same lead as the pos batt cable. There is also another harness (thinner) that comes from over the auto trans tunnel and along the frame rail with a little yellow wire that comes out from there. I'm thinking the wire from the thick harness should go to the solenoid post. As you can see, I have not been able to find service manuals at my local parts stores. I appreciate any guidance and input. Link to comment https://www.classiczcars.com/forums/topic/16381-starter-wiring-question/ Share on other sites More sharing options...
June 27, 200519 yr comment_128705 Here is a link where you can find wiring diagrams. The 75 isn't available, but the 76 would probably work for you.http://www.atlanticz.ca/zclub/techtips/ Link to comment https://www.classiczcars.com/forums/topic/16381-starter-wiring-question/#findComment-128705 Share on other sites More sharing options...
June 27, 200519 yr comment_128709 If the car is an automatic the problem may in the inhibitor switch. If this switch is malfunctioning or out of adjustment you wont get power to the solenoid. It's what we Americans refer to as a neutral safety switch. Link to comment https://www.classiczcars.com/forums/topic/16381-starter-wiring-question/#findComment-128709 Share on other sites More sharing options...
July 7, 200519 yr Author comment_129885 Thanks for your input and advice. The problem was in the starter inhibitor switch for the auto trans. Link to comment https://www.classiczcars.com/forums/topic/16381-starter-wiring-question/#findComment-129885 Share on other sites More sharing options...
