I want to fab a pin remover but haven't found the pin thread/pitch size on any thread I've searched. Could someone provide this info in a timely manner?
I'm not ready to rebuild the rearend on the Z yet and want the tools right there when I start.
https://www.classiczcars.com/forums/topic/16382-spindle-pin-threadpitch-size/
Should be 12mm x 1.25mm on the thread pitch. Do you have the plans to make the pin puller? If not I'll send you the file so you can use it for a reference while getting all the materials together. Will be needing some pretty big "Taps" and "Drill bits".
webdawg1
