Anyone know? I only need these items as the actual joints are new. The PO apparently felt that the boots were unnecessary and left them off. The parts are basically brand new. Even the grease I wiped away had no grudge in it.
Both the steering gear boots and the tie rod end covers can be ordered from a Nissan dealer. ST Boot- 48203-N3400 and Tie rod cover-48522W1401
I had to replace mine because they split.
I hope this is of some help.
The part numbers I listed earlier are for the tie rod end and the steering gear boots. The balljoint cover is available- 40192A8600. You probably will need all of them.
