Posted July 3, 200519 yr comment_129448 hiplease know somebody if it is posible to use a stub axle from any ?? 260Z ore spezial year into a 1971 240Z one of my is damage ?? and i cant find one in germany !!thanks for helpif somebody needs a pic please e-mail to my i can not insert a image on this forum Link to comment https://www.classiczcars.com/forums/topic/16445-stub-axle-from-a-260z-into-a-240z/ Share on other sites More sharing options...
July 4, 200519 yr comment_129491 i believe there is no change between 240z and 260z struts should just bolt inmick Link to comment https://www.classiczcars.com/forums/topic/16445-stub-axle-from-a-260z-into-a-240z/#findComment-129491 Share on other sites More sharing options...
July 4, 200519 yr comment_129493 Springs may be different & require a changeover....sorry, just re-read, yes they will swap, 260 strut is a tad "fatter" and IMO better. use the springs from your 240, otherwise you may have a higher front ride height.... Link to comment https://www.classiczcars.com/forums/topic/16445-stub-axle-from-a-260z-into-a-240z/#findComment-129493 Share on other sites More sharing options...
July 4, 200519 yr Author comment_129509 hii think there is a misunderstanding please look in my gallery you see the pic of the part i need.thanks Link to comment https://www.classiczcars.com/forums/topic/16445-stub-axle-from-a-260z-into-a-240z/#findComment-129509 Share on other sites More sharing options...
July 4, 200519 yr comment_129510 Perhaps you can tell us which photo? Link to comment https://www.classiczcars.com/forums/topic/16445-stub-axle-from-a-260z-into-a-240z/#findComment-129510 Share on other sites More sharing options...
July 4, 200519 yr Author comment_129522 hithe name of the pic in my gallery is -----stud axel 240Z ------ Link to comment https://www.classiczcars.com/forums/topic/16445-stub-axle-from-a-260z-into-a-240z/#findComment-129522 Share on other sites More sharing options...
July 4, 200519 yr comment_129596 well, I can't find it, all the titles seem to be for resto work. You best paste a link as I don't have time to spend hours looking..... Link to comment https://www.classiczcars.com/forums/topic/16445-stub-axle-from-a-260z-into-a-240z/#findComment-129596 Share on other sites More sharing options...
July 5, 200519 yr comment_129627 Well that photo isn't in your member gallery, thats possibly why there has been little response.My bad also, for some reason I've been thinking front strut....as Mick says they will changeover...MOM Link to comment https://www.classiczcars.com/forums/topic/16445-stub-axle-from-a-260z-into-a-240z/#findComment-129627 Share on other sites More sharing options...
July 5, 200519 yr comment_129646 germanZfan said: hiplease know somebody if it is posible to use a stub axle from any ?? 260Z ore spezial year into a 1971 240Z one of my is damage ?? Yes as a complete unit....half shaft flange and stub stay together 240 vs 260.david Link to comment https://www.classiczcars.com/forums/topic/16445-stub-axle-from-a-260z-into-a-240z/#findComment-129646 Share on other sites More sharing options...
