Email logins are now active ×
ZMax Power Formula
KDMatt
I have not used KMax
LOL, neither have I... but if you're referring to ZMax ... :P jk LOL
I wont use any additive in the oil thou ... If you try to '' flush'' the engine you can dislodge particlules that can block oil passages , not a good thing.
Yeah, that's what I was worried about... think ZMax is capable of that?
''goober huh '' :rambo:
Hey now.. I umm.. meant that in a good way... toe-tall-ee! :stupid: :smoke: :classic: :):D :rambo: :eek:
EDIT: Fergot to say thanks! :nervous:
On a strange side-note: My master brake cylinder had been leaking brake fluid into the brake booster for some time before I'd even purchased the car (two months ago). The excess fluid appears to have been sucked into the intake for quite some time. Now that the leak is fixed, the car's not running quite as well. That's probably just coincidence, though. I have done a bit more tinkering than is good for it :)
