Weight of Body Shell
TVollnogle
Does anyone know how much the body shell weighs with everything removed: interior, doors, fenders, engine, drive train, suspension, etc. Curious how heavy it is for transporting on a trailer and building a rotisserie to hold it.
Thanks,
Terry
I doubt it's a 1000 lbs ...
When I had it stripped - on jacks - I could lift the front of the car with ONE finger.
The rear was a pretty easy lift as well, could probably hold it at least a minute on
my own I'd say.
Anyway, we were 4 (non body builder) guys carrying it onto a truck when I needed
to get the Zed to a workshop. Wasn't much of a sweat. The guy upfront
carried the car pretty much all by himself once it was hoisted onto the truck.
Let me tell you - he ain't Hulk Hogan :)
Here ya go.
Thanks for the info. I suspected it wouldn't weigh a lot. Did you have yours on a rotisserie, Philip? Most of the rotisseries I've seen look to be overbuilt, which is not necessarily a bad thing, but I would rather build one as light yet functional as possible. Guess I could have my engineer son do an analysis on my design.
Terry
Terry,
Most rotisseries are built to hold a car much heavier than a Z. We have discussed this several times. Do a rotisserie search. http://www.classiczcars.com/forums/showthread.php?t=5039&highlight=rotisserie
I can lift the front end easily. The back is a little hard to find a place to grab and lift, but I would say two guys - perhaps three - can easily lift an S30 shell.
Thanks guys. I had seen the rotisserie associated with your link during an earlier search, 26th-Z, and it is along the line that I'm thinking. Found this site too during the search and like the lighter design of this rotisserie: http://www.pape.ws/allan_and_rosanne/Z-Car_Stuff/Rotisserie/Dave's%20auto%20rotisserie.htm. I was communicating with Will (hls30) and he has a shell which he just cut up and said he would weigh the pieces if he gets a chance and let me know the weight.
Terry
Alright all you tough guys!!! Over building won't cost near as much as rehab. Even at a mere 450# it will do major damage if it catches you off guard. I used nothing less than 1/4 wall thickness when I built mine. You could hang a bus on it and it wouldn't budge. I've grown real fond of all my parts and pieces being where the belong.
Since he cut it up I'm guessing you'll have to compensate a bit for all the pieces that flaked off over the years. All the holes certainly weigh a good bit less than the surrounding metal.
The car does have holes, but they are more thinning than missing, Still, it chould be pretty close-add 10% back in to be safe(not that 10% of the entire shell has been lost to rust). I would rather have a slightly high figure than a low figure. I am using a plasma cutter to trim it up, so it is eating some metal too. I have one cut left to do, the bottom of the firewall(gotta scrape the sound deadening off-too much smoke and blowback!
If the rain will stay away in the afternoons, I will finish cutting it up next week, and get the weight of the pieces posted. I don't want to use a plasma cutter in the rain!!!
Will
Three of us lifted my shell onto the trailer. It was very light for us. I think the 400-450 range is correct. My rotisserie is designed to work with any vehicle up to 3500#. We used 1/4" thick 4" tubing to build it. It will hold a fullsize car, no problem.
  • Who's Online   2 Members, 0 Anonymous, 775 Guests (See full list)
