Posted July 18, 200519 yr comment_130967 whats the best way to get rid of/ prevent rust under the battery tray? Sand blasting? What do I do? What's a good rust remover? Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/ Share on other sites More sharing options...
July 18, 200519 yr comment_131001 I'm planning on relocating my battery behind the pass. seat while I tackle the rust under mine. I think it's best to remove the battery tower by drilling out the spot welds. You can then sandblast,grind,wirewheel the metal to see how bad it is. If it's bad I would cut and weld in new metal. You can then clean up the tower, reweld back to the car and paint with por 15. They sell those felt mats for under the batteries to prevent acid from leaking onto the car body. I think I'm just gonna leave mine behind the seat as permanent prevention Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-131001 Share on other sites More sharing options...
July 18, 200519 yr comment_131002 Well if it's not to bad u can sand blast it and patch with por or rust bullet. then relocate the battery with an optima one Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-131002 Share on other sites More sharing options...
July 27, 200519 yr comment_132181 I removed the tray with a spotweld cutter. Be vary careful , I went through the inner fender in a couple of places . I was having some welding done any way so I just added it to the list. I through bolted mine back in after I cleaned off all the rust with a sand blaster and metal ready and a generous coating of POR . By bolting in place using stainless bolts and locking nuts I still have por in between the supports and the inner fender . At least this is my reasoning. I also treated the stand well on all sides , which is nearly impossable with it welded in place. I have pictures if interested. send me a PM with your email address . Gary Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-132181 Share on other sites More sharing options...
July 27, 200519 yr comment_132186 Don't forget to install an electronic rust preventer system. Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-132186 Share on other sites More sharing options...
July 27, 200519 yr comment_132225 TomoHawk said: Don't forget to install an electronic rust preventer system. With POR15 why bother? The best way to keep this from happening again is not only to POR15 the area but then go to a battery like an Optima. Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-132225 Share on other sites More sharing options...
July 27, 200519 yr comment_132235 those optima batters can take a beating. i love those things and will not go with anything else. Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-132235 Share on other sites More sharing options...
July 27, 200519 yr comment_132237 The P.O.R stuffonly treat a small area. You also want to take care of the rest of the car. Like with an electronic rust preventer. Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-132237 Share on other sites More sharing options...
July 28, 200519 yr comment_132328 TomoHawk said: The P.O.R stuffonly treat a small area. You also want to take care of the rest of the car. Like with an electronic rust preventer.I get your point now. I thought that we were only talking about the battery tray, but yes your car can and will rust in many other locations if not treated and properly prevented. Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-132328 Share on other sites More sharing options...
July 28, 200519 yr comment_132329 TomoHawk said: The P.O.R stuffonly treat a small area. You also want to take care of the rest of the car. Like with an electronic rust preventer.Why do you say this? It treats whatever size area it's applied to. Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-132329 Share on other sites More sharing options...
July 28, 200519 yr comment_132337 classicZCan you tell us how much rust or what type of progression you have? Surface rust on the sheet metal or big holes that need to be repaired?Can you tell us exactly where the rust is - on top of the battery stand, under the stand on the innerfender, down on the front frame rail???Better yet, can you post a picture of that area with the battery removed?I wouldn't drill the spot welds out for light surface rust..Once we know the above ... we might be able to make a recommendation as to the best approach...regards,carl B.Carl BeckClearwater, FL USA Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-132337 Share on other sites More sharing options...
July 28, 200519 yr comment_132340 i have rust thats cancerous that eat away at the firewall and battery area. If it's only surface rust i'd just sand blast it then coat with like por or rust bullet. U can poke around with a screw driver Link to comment https://www.classiczcars.com/forums/topic/16596-battery-tray-rust/#findComment-132340 Share on other sites More sharing options...
