engine won't turn over
rclayton12
My '73 240z with manual trans was running great, but all of a sudden I couldn't get the engine to turn over at all, it has happend once before, but i got a friend with a honda s2000 to jump me off just fine. I have replaced my started and cylinoid, and the batter is good please help!!!
I have a 75 280 and recently had similar troubles. The problem was in the neutral safety switch (inhibitor switch). The car is an automatic but there may be one on manual models too. When this switch goes bad, it will sometimes allow the car to start - sometimes not. I could sometimes start the car by moving the gear selector to neutral or drive to start it (play with it). I fixed the problem by taking the switch off and cleaning the connections. They were covered with 30 years of crud. Hope this helps.
