well I can tell you it's not the turn signal and I sadly can't just make left turns because of city engineering and I'm not blonde. Umm, good point though...it doesn't have the rpoblem when I turn the wheel while stationary and parked. So Ummm I still have no clue someone help me because I can't find anymore wires to fix for now. At least not until I find some more...
Well guys, I think I may have solved the problem. Like I said, I went to look for more wires and sure enough I had found one that was hanging quite loose. It was right under the steering wheel and I'll show u guys a pic of it later today. Now, it had nothing to do with the steeing wheel, since it worked stationary, but I noticed that the way the wire was loose, it would only disrupt turning left. Anyways, I fixed that by cutting and re-wiring/re-crimping and then I went out for a drive. I went out to the industrial area here at 130, about 40 mins ago and on my way there it worked fine. Once I got there I did some high-speed S turns and pulled a couple 180's and some donuts left and right and I still had a working sound system. Let's hope it's not tricking me and thanks for the help guys!! I'll post the pic later and if I need any other wiring help I'll just post another thread or reply...thanks again guys...
