Phacade Posted May 15, 2002 Share #1 Posted May 15, 2002 Just looking for a little help here with my '75 280Z. I was coming home yesterday and on the last turn before my house, I pressed the brake. My petal starts going down slowly but down further than it has before and makes an audible hiss when pressed. I checked the fluid and both fluid conisters on the master cylinder were half full. I topped off and (I know silly but had no choice) drove to work this morning. It stops. Kinda. But takes me 4 times the distance to stop and makes a hiss whenever pressed. Master cylinder? Master Vac? Line? Help. Link to comment Share on other sites More sharing options...
Rob Posted May 26, 2002 Share #2 Posted May 26, 2002 Sounds to me like the diaphragm in the booster is kaput. If the line was leaking you would get a constant vacuum leak and the motor would idle high. I think it's possible to service these yourself but I've never actually needed to do it. Link to comment Share on other sites More sharing options...
Phacade Posted May 27, 2002 Author Share #3 Posted May 27, 2002 I posted this here and a few other places and that was the general thought. Sunday I switched out both the booster and the master cylinder (just to be safe). Works great, I can stop; and thats a good thing. Link to comment Share on other sites More sharing options...
Rob Posted May 28, 2002 Share #4 Posted May 28, 2002 Yes, being able to stop is a good thing! Years ago I had total brake failure (handbrake didn't even work as it was hydraulic) in my rally car while driving to uni. As I didn't want to leave my car on the side of the road I decided to keep going, and learned the meaning fear as I slowed the car down with the gearbox, and stopped it by turning off the engine and gently using the clutch as a brake. Stoopid!:eek: Link to comment Share on other sites More sharing options...
