Posted August 6, 200519 yr comment_133227 78 280z. Cannot find EFI relay. Haynes efi troubleshooting manual says it is near drivers kickpanel above control box. This would be other side of firewall from dropdown resistors. It is not there. Clymer manual ambiguous as to exact location as well. Wiring schematic shows just off control box. Wrong. Any ideas. Thanks for informed advice. Link to comment https://www.classiczcars.com/forums/topic/16808-help-newby/ Share on other sites More sharing options...
August 6, 200519 yr comment_133230 http://www.classiczcars.com/forums/showthread.php?t=15524&highlight=EFI+relayThis should help you. Link to comment https://www.classiczcars.com/forums/topic/16808-help-newby/#findComment-133230 Share on other sites More sharing options...
August 7, 200519 yr comment_133298 pleiades said: 78 280z. Cannot find EFI relay. Haynes efi troubleshooting manual says it is near drivers kickpanel above control box. This would be other side of firewall from dropdown resistors. It is not there. Clymer manual ambiguous as to exact location as well. Wiring schematic shows just off control box. Wrong. Any ideas. Thanks for informed advice.For easier location of parts and better information on repairs, I suggest that you look into getting a factory service manual. You can purchase it electronically from Courtesy Nissan at http://www.courtesyparts.com/secondtier_s30.html.Good luck. Link to comment https://www.classiczcars.com/forums/topic/16808-help-newby/#findComment-133298 Share on other sites More sharing options...
August 7, 200519 yr comment_133320 I think I posted this in the thread that Corganx33 referred to above. The EFI relay is under the bracket, behind the fusible link covers on the right side between the shock tower and the battery. See the attachment in that post. BTW, what makes you think your relay is bad? I ask only because I've worked on these cars for years and never had a problem with an EFI relay. Oh, and the dropping resistor is on the drivers side next to the clutch master cylinder, not that you should ever have a problem with that either. Link to comment https://www.classiczcars.com/forums/topic/16808-help-newby/#findComment-133320 Share on other sites More sharing options...
April 6, 200817 yr comment_243099 it is a long rectangular relay under the dash on the drivers side. It should also have two connectors plugging in to it. hope that helps. Link to comment https://www.classiczcars.com/forums/topic/16808-help-newby/#findComment-243099 Share on other sites More sharing options...
April 6, 200817 yr comment_243100 zmaster: Check the dates on the threads you are posting to. This one had been dead since 2005 until you resurrected it... Link to comment https://www.classiczcars.com/forums/topic/16808-help-newby/#findComment-243100 Share on other sites More sharing options...
