SteveInOakland Posted August 11, 2005 Share #1 Posted August 11, 2005 Hi, First post here. Owned two in the past -- a 1972 240 during the '70s, and a 1976 280 during the '80s. Loved both. Loved 240 more but harder to live with. Would like to get back in.Request: can somebody with a 1972 or 1971 tell me the weight spec displayed on plate on the door jam? Trying to get an exact fix on the weight spread vs. a 1973 or a 260. I know it's come up before, but to avoid apples-and-oranges, it'd be nice to have that official spec.Many thanks. This forum looks terrific.Steve in Oakland. Link to comment Share on other sites More sharing options...
MikeW Posted August 11, 2005 Share #2 Posted August 11, 2005 The weight is not on the door tag. My 1972 Factory Service Manual lists the following. I copied this exactly but note that there seem to be problems with the numbers. In the US and Canada the automatic seems to weigh 50lbs more but in other areas it only accounts for 2kg (or 4.4lbs) even though it's listed as 70lbs more. I tried to format this as a table but it wouldn't happen.HLS30UV 1,066kg 2,350lbs USA and Canada 4-speed manualHLS30AUV 1,089kg 2,400lbs USA and Canada 3-speed automaticHLS30 1,043kg 2,300lbs LHD 5-speed manualHLS30A 1,045kg 2,370lbs LHD 3-speed automaticHS30U 1,043kg 2,300lbs RHD 5-speed manualHS30AU 1,045kg 2,370lbs RHD 3-speed automaticHLS30Q 1,043kg 2,300lbs LHD for Europe 5-speedHS30Q 1,043kg 2,300lbs RHD for Europe 5-speed Link to comment Share on other sites More sharing options...
CoastGuardZ Posted August 11, 2005 Share #3 Posted August 11, 2005 1972 240Z here with original dealer installed A/C ... 2330 lbs.Nate Link to comment Share on other sites More sharing options...
SteveInOakland Posted August 12, 2005 Author Share #4 Posted August 12, 2005 Wow, thanks to you both. I've seen some eBay photos showing weights of 2700-2800 lbs for 1973 models, on the door plate. Anybody have a book that lists something else? I wouldn't have thought the spread would be this much. My Clymer's book is long gone, unfortunately.Thanks again,Steve Link to comment Share on other sites More sharing options...
beandip Posted August 12, 2005 Share #5 Posted August 12, 2005 My '73 went 2620 with a half tank of gas and 220 lbs of me inside. It's an a automatic and had a spair and the jack and the factory tools . The emissions stuff has been removed and I have 240 bumpers . Gary Link to comment Share on other sites More sharing options...
Curtis240Z Posted August 12, 2005 Share #6 Posted August 12, 2005 My '71 240Z with full interior, L28, 5-speed, R-200, 3/8 tank of gas, no tools, no spare tire = 2371 lbs Link to comment Share on other sites More sharing options...
CoastGuardZ Posted August 12, 2005 Share #7 Posted August 12, 2005 My '72 doesn't have any weights listed on the door jamb, I wonder if the #'s you've seen there are GVWR, which is the max the car should weigh with luggage, people, etc.In my glove box there is a sticker that say's permissable vehicle load capacity 420 lbs. That would equal ~ 2750 lbs. , a bit closer to the #'s you mentioned.FWIW,Nate Link to comment Share on other sites More sharing options...
deadflo Posted August 13, 2005 Share #8 Posted August 13, 2005 I weighed my series one at a local waste disposal place. With three gallons of gas and no occupants it was 2235. I swear.The car has no emmissions gear (pump/galley/gizmos) Link to comment Share on other sites More sharing options...
