I feel stupid for asking this...
theianmonster
You would need a clutch/brake pedal assy. for the interior and a clutch master cylinder and slave cylinder, as well as all the hydraulic piping for same. You may also need to modify the console for the manual shifter. The flywheel is different also. Any body else that has actually done this, feel free to jump in and correct/clarify/expand on this info.
And:
Acquire a throwout bearing collar to match the clutch you buy.
Remember to remove the automatic bushing in the end of the crankshaft.
Jump out the neutral safety switch.
Acquire the manual flex plate.
Fabricate a clutch pedal stop.
If you haven't already try searching for this on the forum...we have discussed it many times...I myself even asked about this swap a couple years ago. You should be able to locate answers to all your questions fairly easily.
curtis240 the manual has a flywheel the automatic uses a flexplate. there is no crank shaft bushing for the automatic applicatoion, one is needed for the manual trans installation. It is true the automatic used a rad with a oil cooler in the lower tank . It will work fine with the manual trans , just remove the oil lines and forget it. as for all the questions about the difference of this part and that . the club sells a CD that has the entire program that the dealers use , showing part numbers and all . Drop the $20. it is worth it.
I am refering to the CD that the club has for sale . It doesn't have instructions on how to do anything . It is the same information that the Nissan Dealer has when they look up part numbers . It has exploded views of the various systimes and it shows what the individual part numbers are. I bought mine 4+ years ago and unless I am wrong it was $20.00 .
  • Who's Online   1 Member, 0 Anonymous, 850 Guests (See full list)
