attention sblake01 and others
DatsunZsRule
As you know from my last post, I'm doing work to my front end. I was just flipping throughmy FSM just to refresh my memory on a couple things and one thing I saw in the FSM under reinstallation of front brake pads they say to apply "Pad Grease" to working portions of caliper and both sides of anti-squeel shims. My question is about the "Pad Grease" Is this some sort of special grease for the brake components only or can any light coating of multipurpose grease be used?
Thanks in advance.
