Posted August 17, 200519 yr comment_134434 I just drug home a 70 (8/70 #9033) with AT and A/C, been sitting since 84 and all looks original. Had planned on a complete resto(floors and rails main problem) but the motor has me puzzled, it has the L24 stamped but the motor number boss is blank, parked way back in 84 and it looks it, still got the 2400 valve cover, right carbs etc, but I can't see any evidence of a stamping at any time. Oil, soap, brass brush, more soap etc, see nothing, I put a machinist straight edge across the 2 bosses and they are right in line. Looks to me if the number was ground off it would have knocked at least a couple thousanths off. What gives? Will not be a resto(at least by me) if I can't make myself feel good about it being the original motor. Factory(Dealer) replacement? Older swap?, it was 15 when it was retired, plenty of time to kill a motor and put in a rebuild. Any thoughts? Thanks, Mike in Arkansas Link to comment https://www.classiczcars.com/forums/topic/16925-70-z-l24-no-motor-number/ Share on other sites More sharing options...
August 17, 200519 yr comment_134449 Hey mike what part of Arkansas are you from? That sounds really strange for the number to not be their. evan if it was a rebuild it would have some kind of a number on it. Least i would think so. Keep cleaning and look over the whole block it should be their. Ps. Im in Vilonia Link to comment https://www.classiczcars.com/forums/topic/16925-70-z-l24-no-motor-number/#findComment-134449 Share on other sites More sharing options...
August 17, 200519 yr comment_134472 Mike,If the number had been ground off there would surely be tell tale signs of grinding. Most unusual. Perhaps stolen at some time in the past ??????????It happens.You are looking in the right place aren't you ?????? Right hand side towards the rear ?????????????????Rick. :devious: :devious: Link to comment https://www.classiczcars.com/forums/topic/16925-70-z-l24-no-motor-number/#findComment-134472 Share on other sites More sharing options...
August 17, 200519 yr comment_134473 I have seen in the past new bare blocks ordered from the manufacturer come with no engine number stampings.One case in point was an RB30 block straight from Nissan. Link to comment https://www.classiczcars.com/forums/topic/16925-70-z-l24-no-motor-number/#findComment-134473 Share on other sites More sharing options...
August 17, 200519 yr comment_134479 Welcome Mike--- Another Arkie here----I'm in Bentonville, Arkansas Link to comment https://www.classiczcars.com/forums/topic/16925-70-z-l24-no-motor-number/#findComment-134479 Share on other sites More sharing options...
August 17, 200519 yr Author comment_134480 I am in Little Rock, there looks to be "swirl" marks on the pad but like I said with a straight edge there is no material missing from the motor number boss. Link to comment https://www.classiczcars.com/forums/topic/16925-70-z-l24-no-motor-number/#findComment-134480 Share on other sites More sharing options...
