my clock on dont work in my Z!?
BuDavid
the electrician screwed the PCB of the clock! I should find an alternative mechanizm for it, I thaught of the BMW's 3 series clock form the model arround 1990, it is very accurate and can be adjusted by two push buttons, but I have to be sure that the mechanism will fit or not yet, then i have to make a way to hide the adjust bottons somewhere in the glove box or anywhere else! if I use a different mechanism i shold consider adjusting, coz the hands shaft should be reached by the adjustment elmo on the glass of the clock so it could be adjusted;)
I'll look for it and update.. bye now
