Posted August 19, 200519 yr comment_134810 i posted in the general 240,260,280 help me but ill try here too.tomorow i am buying a 280z it needs fuel pressure regulator to run(it starts but floods) where is the fuel pressure regulator located on the car and how hard is it to change. also what tools will i need to do it. thanks Link to comment https://www.classiczcars.com/forums/topic/16962-280z-fuel-pressure-regulator/ Share on other sites More sharing options...
August 19, 200519 yr comment_134812 To change it basically all you need is a phillips screwdriver, a 10mm socket, a ratchet, and patience. Link to comment https://www.classiczcars.com/forums/topic/16962-280z-fuel-pressure-regulator/#findComment-134812 Share on other sites More sharing options...
