OK I am asking a group of car folks "where to stick it?" My 70 was a work in progress, part of that was aftermarket water and oil temp and oil pressure guages. The oil temp probe(1/4" x 3" approx.) needs a home. Is there a logical place for the probe? Should I add a plumbing nightmare around the factory oil pressure fitting (mechanical oil pressure and the temp probe) hole? Mike
Hi Mike,
My own experience is that it should be in the oil pan. Need a weld in bung fitting to match your temp sender. I've seen them at Jegs and Summit and other speed shops.
Chris
