A 240k five speed will fit fine.
So will just about any other Datsun gearbox! I had a 180B box in my 260 for a while, and it was fine. Bolted right in and didn't break.
Another option is to buy the synchro & a workshop manual and fit it yourself. Datsun gearboxes aren't hard to work on.
You can also get a silvia box to fit. Take a look at
http://www.usq.edu.au/users/degroot/240z/main_default.htm
There is a page there somewhere about how to do that.
$240 Isn't that bad a price for the work involved (I'm assuming you are talking aussie $$$ and they are doing the removal/replacement of the gearbox), but you shoudl be able to do it yourself for less than $100.
Good luck.
https://www.classiczcars.com/forums/topic/1702-gearboxes/#findComment-7628
