This is the first time using this forum, and I need help!! I'm restoring a 260z 2+2 interior carpet and can't find a company that might be able to help! I called motorsport Z car and can't seem to get a good answer to a good quality carpet. My understanding is that all years from 74 - 78 are the same, why can't I use a later years carpet to fill my needs. Any help would be appreciated!!!!!!!!!!!!!
https://www.classiczcars.com/forums/topic/17076-interior-help-260z/
The floors are a little different between the years, if the later year you choose has too much carpet-you could have it cut and rebound, if it has too little, you would see some of the floor.
Here are some suggestions:
If they do not specify 260 2+2, call them and be sure.
http://www.stockinteriors.com/autocarpet.asp?Itemid=3134&MakeId=38&ModelId=314
http://www.auto-interior.com/datsun1.html#260Z
http://www.automotivecarpet.com/product/datsun/74_260Z.html
https://www.accmats.com/crl/ShoppingCart.aspx
Will
