August 30, 200519 yr Author comment_136249 I wish i was smoking the other stuff I might upload the pic with the foil around it opp ithink i all ready have ok Question how much power does it take to cut out conrod bearings is 30 days 33 cc in chamber ? Question lower compression to 45 cc in the chamber 20" n 30" shells, lasts for 8 months how much power? Run an engine WOT with ~28 degrees too much advance Question how long will the pistons last ? fact wheels used to spin easly in second gear ,provided they were spinning in 1st Question how much HP? so these are some of the things i have allready done and will do again there are real performance gains fact going from L20 b cam to L18 cam reduced knocking by a few degrees fact knocking was heard above 3000 Rpm @ 3-4 BTDC L20 b cam Question calculate Engine VE? So im willing to use anything and everything So think about this feed you engine with a liquid slussie of fuel an O2 then push the compression through the roof to insane levels blow up a few engines in the process ,been there in theriory you have just made a refigrator that works at 6000 rpm The perfict engine Copyright 2005 By smokingwheels@yahoo.com PS: My Grandfather was a dentist so i can't show my face on T.V. Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136249 Share on other sites More sharing options...
August 30, 200519 yr comment_136252 PS: My Grandfather was a dentist so i can't show my face on T.V.Ahh, laughing gas, now I understand.... Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136252 Share on other sites More sharing options...
August 30, 200519 yr comment_136253 I think you have all been smoking something Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136253 Share on other sites More sharing options...
August 30, 200519 yr Author comment_136260 well i didnt have smoking stuff on my mind but now you guys mentioned it http://smokingwheels.myphotoalbum.com/view_photo.php?set_albumName=album03&id=powertrying thishttp://smokingwheels.myphotoalbum.com/view_album.php?set_albumName=album03page 2say no more ill probley get booted for this Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136260 Share on other sites More sharing options...
August 30, 200519 yr comment_136281 The only reason we're saying you're smoking stuff is because you are making no sense at all. You are either smoking the happy-grass or you are 6 years old using your dad's computer. Which one is it? Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136281 Share on other sites More sharing options...
August 30, 200519 yr Author comment_136341 The only reason we're saying you're smoking stuff is because you are making no sense at all. You are either smoking the happy-grass or you are 6 years old using your dad's computer. Which one is it?may be i could send you sum mp3s of my lastest engine withvac secondarys opening up with no load on engineor upload them then you guys might think differentim away for a few days Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136341 Share on other sites More sharing options...
August 31, 200519 yr comment_136414 WTF is going on.. someone close this thread Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136414 Share on other sites More sharing options...
August 31, 200519 yr comment_136426 Add some one way valves one on the engine air intake side and one on a cold air intake side. and if that does not work them the hole thing could be modified to administer the other type of smoke that SavannahZ refered too.Now I was smoking the other day and I thought of how my car runs better on cold days than on a hot summer day, so...I thought I could install A/C on my Z, but route all the cold air produced by it, directly to my air horns...kind of a Datsun "RAM AIR" System providing me with the "cold" day effect and my car running better. any thoughts on this idea. **"DATSUN "RAM AIR" Is a copyright of Jackboxxx Inc. Patent Pend.** :devious: Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136426 Share on other sites More sharing options...
August 31, 200519 yr Author comment_136436 Its good to here someone is on the same pageIm looking at the smaller things like gaining .1 % more powersimple find enough of these and you will end up with more power than you hadyep its true the colder the air the more dense you can patent that one my idear is to make a foam box to fit in my wagon approx 1.2 CM thenuse the aircon to cool the air in the box you should be able to get it down to - 20 cthen feed the air in unrestricted into you enginefor a burst of hmm about 10 seconds at WOTyou can get a sum cool tools free at http://www.turbofast.com.au/freesoftware.html look at cfm rpm etc Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136436 Share on other sites More sharing options...
August 31, 200519 yr comment_136449 WTF is going on.. someone close this threadWhy? It's just two dam funny watching this guy stomp all over common sense, basic mechanics and physics. What's next? Electric leaf blower boost? Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136449 Share on other sites More sharing options...
August 31, 200519 yr comment_136467 Why? It's just two dam funny watching this guy stomp all over common sense, basic mechanics and physics........ My thoughts exactly! This thinking is way, way, way outside the box. Did you catch his response in the 'Engine missing above 5k' thread? Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136467 Share on other sites More sharing options...
September 1, 200519 yr Author comment_136623 Why? It's just two dam funny watching this guy stomp all over common sense, basic mechanics and physics. What's next? Electric leaf blower boost?hmm well ok more flow than a vac so about 5 kilopaslls boost hmm ~10kw increase for 2 kw drain off motorso rewire the altnator split 3 phases add voltage doublers then put in series summing the output a guess of about 220 volts dc if you drive the rotor hard enoughtit should handle 20 volts for short periords I will have to try that one thanks for the incentive Link to comment https://www.classiczcars.com/forums/topic/17083-small-turbo-cheap-diy/?&page=2#findComment-136623 Share on other sites More sharing options...
