Need Parts?
theianmonster
71datsunZ -
Someone beat you to the control panel. I have really worn out vent emblems, I have side turn signal metal parts, I have the tool box doors, and specifically what window trim (which windows). Also, how many turn signal metal parts do you need?
agemeansnothing -
I have the center consol (but its for an automatic). I also have an oil cap.
- Ian
Hatch Hinge Rubber "pocket" Seals; Right and Left
(These fit IN the body and over the hinge itself. They usually have a flat metal piece that holds the rubber behind the hinge bolts.)
Headlight Acorn Rubber Mounting pads. Right and Left.
(This is the flat rubber gasket that goes between the "acorn", that is the acorn shaped headlight case, and the headlight support that's on the fender.
Interior Plastic Finishers Any and All
Console (Series II) with Center Fuse Cover.
Hatch Pneudraulic Support Rod.
Ignition, Hatch, Glove Box, Both Door Locks.
Sun Visors, Left and Right.
If you have any of these, let me know what condition they're in and how much you're asking for them.
Enrique
  • Who's Online   2 Members, 0 Anonymous, 817 Guests (See full list)
