Ok, so I'm working on the front suspenion currently. I've got the calipers off and apart so I can rebuild and paint them. Without thinking I seperated the halves of the calipers, then later reading in Wick's book, I realized that what I just did is undesireable. He says its best not to break the internal fluid seal between the halves. So now that they are apart what should I do to reseal it? I was thinking it may be possible for them to be resealed just by attaching the caliper halves back together, but this is the kind of thing I want to be sure about, make sure it is done correctly. Any help is appreciated to expedite my Z restoration.
https://www.classiczcars.com/forums/topic/17148-240z-stock-caliper-rebuild/
you are supposed to, but if you return the cores 5 days after you buy the calipers.....will the guy remember what you bought 5 days previously? will he care? what if a different guy is behind the counter when you return the cores?
