Posted September 4, 200519 yr comment_137013 Need some help in the "how to remove these" departmenttake a look.http://www.cardomain.com/ride/631840/7I've tried the method using two sockets, one larger than the bushing, 1 smaller than the bushing, press them out with a vice... doesn't seem to do any good.Anyone else have a better method to removing these?Thanks Link to comment https://www.classiczcars.com/forums/topic/17151-removable-steering-u-joints/ Share on other sites More sharing options...
September 4, 200519 yr comment_137025 Just two questions.Why are you replacing them?Have you found a correct replacement? Link to comment https://www.classiczcars.com/forums/topic/17151-removable-steering-u-joints/#findComment-137025 Share on other sites More sharing options...
September 5, 200519 yr comment_137063 Are they not held in with circlips like the other u joints, and, what ed said ^^^^^ Link to comment https://www.classiczcars.com/forums/topic/17151-removable-steering-u-joints/#findComment-137063 Share on other sites More sharing options...
September 5, 200519 yr comment_137081 I do not believe that is a replaceable U-joint. WAY back in the late '70s, I was trying to get rid of shimmy on my '71 240Z, and thought that joint was sloppy. Even back then, the best I could do was grab one off a parts car that looked better. I actually found an entire NOS assembly with that U-joint last year on e-bay. Going into my 240Z restoration now...Oh, and BTW, on my '71 all those years ago - it wasn't the problem... Link to comment https://www.classiczcars.com/forums/topic/17151-removable-steering-u-joints/#findComment-137081 Share on other sites More sharing options...
September 5, 200519 yr Author comment_137082 They are cheap and I might as well replace it while its out of the car? EDIT: I thought they were at least, now that you've asked I can't seem to find where I found the replacement part. I thought VB had them, but looking in their catalog I now can't seem to find them. Either way, its not that they need replacing so much as it is what I said in the next paragraph.I don't really have a solid answer. I was going to paint the steering column shaft while it was out of the car to match the rest of the suspension, semi-gloss black. Would prevent anymore corrosion from forming, I've wire brushed and steel wooled most of the rust/corrosion/dirt off the shaft and wanted to paint it, but I didn't want to paint over the joint shown while it was together, figuring that the first time it was moved it would chip the paint.... No circlips, its supposed to be a press fit, and I've seen a few how-to's on how to remove them... but they don't work. I'm thinking the how-to's might have been for a different year, which may have had a slightly different u-joint here. Link to comment https://www.classiczcars.com/forums/topic/17151-removable-steering-u-joints/#findComment-137082 Share on other sites More sharing options...
