Posted September 8, 200519 yr comment_137459 I am stuck on what to cut off and what to keep in the turbo intake manifold. I know I might need to keep some of the holes but which ones and where do the lines go? If you have pictures of your install, I would greatly apreceate it. I don't want to get all crazy with cutting things off I might need. Thanks Link to comment https://www.classiczcars.com/forums/topic/17197-turbo-intakeneed-help/ Share on other sites More sharing options...
September 9, 200519 yr comment_137519 Brian, Depends what you want to do I suppose. I used a non-turbo intake manifold as I couldn't find one and plan on making a custom one anyway. I cut off the valve on the very end, then cleaned out the copious amounts of crap in the gallery that runs next to the plenum on the underside. I also discovered holes that go through this and into the runners! I tapped these and plugged them. I also converted to cable throttle and cut off the ugly towers. Hope this helps, Dave Link to comment https://www.classiczcars.com/forums/topic/17197-turbo-intakeneed-help/#findComment-137519 Share on other sites More sharing options...
September 9, 200519 yr comment_137544 I was wondering where or who did you get your header for your turbo made or done at, I like how you worked that and what type of stand alone set up are you using becuase obviously your a bit far from stock.Good looking turbo set up you have there. Link to comment https://www.classiczcars.com/forums/topic/17197-turbo-intakeneed-help/#findComment-137544 Share on other sites More sharing options...
September 10, 200519 yr comment_137588 Thanks boostedz,The exhaust manifold was fabricated by Ian Rowlerson who used to run a TIG welding business in Warburton, Victoria, Australia.I'm running a base-level Autronic SMC. Wouldn't do that again. Its a good enough computer for a basic engine, but there are things I want to do that I can't, great for the price though.Dave Link to comment https://www.classiczcars.com/forums/topic/17197-turbo-intakeneed-help/#findComment-137588 Share on other sites More sharing options...
