1978 Z Electrical Problems
Datsun-Fever
I think my voltage regulator just went, because i can start the car fine, but it lacks power and sometimes backfires, but when i connect jumper cables from another car, it runs perfect, i wanted to know if the voltage regulator is internal on the 78, because i had my battery and alternator tested, and they are both fine....any thoughts?
The VR is definately internal on a '78. Low voltage will certainly mess with the FI and cause things to act wierd. But if you had the alternator tested, didn't they test the voltage too?
