on what you want it made from
glass or urethane.
My shop, Motorsport Whse in Tucson is a dealer
for Xenon and a few other manufacturers.
Years ago there use to be a company we bought from called
Pacific, they and A&A Fiberglass both had some really cool stuff. Too bad they have gone bye bye over the last 10 yrs.
We had a discussion on the IZCC mailing list, and data was presented that indicated that the BRE spook performed the best of all spoilers/air dams tested. I do not have a technical report in hand, so don't ask. This does not mean that the other products performed poorly.
You can get that air dam from Motorsports zcarparts.com
Two things to think about when you decide what material you want it made from.
1. urethane will not break when you drive into a curb or scrape a speed bump, but at highway speeds it will bend and your paint will crack and peel off.
2. fiberglass might crack or break if you hit a speed bump but it can be easly fixed, and if you are carefull of bumps or curbs, the fiberglass is very durable and the paint wont peel.
Also you can easly make a mold from a fiberglass so you can make your own replacement air dams.
