Posted September 16, 200519 yr comment_138309 Ok, So i'm on my way home today, and some kid in his brand new Hyundai Tiburon GT thinks his car is faster than mine. Naturally he finds out its not . Unfortunately, this comes at a cost to me. I get home to find out my Fuel Pressure Regulator dripping gas. I was hoping it was just one of the hoses connecting to it that cracked, becuase I can not find anywhere on the regulator itself that appears craked. Unfortunately, after replacing all the hoses gas is still dripping off of it. So I looked at MSA and VB and both have replacements for $60+ plus shipping, and a special order one from Autozone is $42. Is this something I can pull off of a parts car? I'm still recovering from the heater valve that I ordered 3 weeks ago (which still hasn't come BTW) and would rather not have to fork over another $60. Would this be a foolish thing to do? or would it be okay, assuming the used one is clean and appears in good shape. If I shouldn't use it, does anyone know where I could get one cheaper? Link to comment https://www.classiczcars.com/forums/topic/17279-fuel-pressure-regulator/ Share on other sites More sharing options...
September 16, 200519 yr comment_138313 A simple search on this club site turned up this: http://www.classiczcars.com/forums/showthread.php?t=18449&highlight=Fuel+Pressure+Regulator This thread is only a few days old.I can understand the need for conversation at times by not looking for answers yourself, but like the old saying goes, "God helps those who help themselves". Link to comment https://www.classiczcars.com/forums/topic/17279-fuel-pressure-regulator/#findComment-138313 Share on other sites More sharing options...
September 16, 200519 yr comment_138323 If you have access to a parts car, try it. Like I said in the other thread, they seldom go bad. Link to comment https://www.classiczcars.com/forums/topic/17279-fuel-pressure-regulator/#findComment-138323 Share on other sites More sharing options...
September 18, 200519 yr comment_138499 I cant see how you could say they seldom go back when it is a rubber diaphram that is vacumn operated and has been on a car that has high underhood temps for 25+ years.They do go bad, and if you are having a leak at the FPR I would definetly say it is bad. Dont go to MSA or VB, get it locally. Cheaper and faster, plus it comes with a warranty.If you do have a parts car, and you think the FPR is good on that car then use it to replace your defective one. Link to comment https://www.classiczcars.com/forums/topic/17279-fuel-pressure-regulator/#findComment-138499 Share on other sites More sharing options...
September 18, 200519 yr Author comment_138510 I got one off a 75 Z and it works fine. He charged me $20 for it, but at least it works. Got the car up and running the next day. Link to comment https://www.classiczcars.com/forums/topic/17279-fuel-pressure-regulator/#findComment-138510 Share on other sites More sharing options...
September 19, 200519 yr comment_138544 I cant see how you could say they seldom go back when it is a rubber diaphram that is vacumn operated and has been on a car that has high underhood temps for 25+ years.They do go bad, and if you are having a leak at the FPR I would definetly say it is bad. Dont go to MSA or VB, get it locally. Cheaper and faster, plus it comes with a warranty.If you do have a parts car, and you think the FPR is good on that car then use it to replace your defective one.In my experience, they seldom go bad. I have never had one personally go bad and the only one I have personally seen go bad was damaged by the person working on the car. Link to comment https://www.classiczcars.com/forums/topic/17279-fuel-pressure-regulator/#findComment-138544 Share on other sites More sharing options...
