Email logins are now active ×
de-smogging a stock american 1974 260z?
agnyc1
i want to maximize gas mileage and power, and essentially get it running as efficiently as an early 240z. (yes, i realize it's heavier, but that aside..) (i'm smog exempt in southern CA, so i can remove/change/strip.)
aside from changing the flat-top "boat anchor" SUs to early round-top SUs,
what else do i need to do, specifically with regard to emissions controls, to get it running like a 70 or 71 240Z?
Carefull with that axe Eugene.....
You are exempt from manditory annual inspection. Removing or defeating smog devices is still unlawfull and prohibts your car from operation.
But......
99 percent of the smog air pumps out there no longer work and actually hurts your cars performance which increases your pollution emmisions. So, That's where most start in their engine clean-up efforts.
i studied your diagram and it makes sense to me that the PCV and vapor system would only help fuel efficiency and not really hinder engine performance
is this true? or does it hinder performance? if so how much?
does this system cause the dreaded vapor lock i keep hearing about?
Vapor lock is typically caused by the high underhood temperatures that the lean mixture of the flat-tops create.
PCV and vapor systems have no measurable effect on performance or driveability.
The term "dizzy" is short for distributor. There are gains to be had by using a dizzy with a different advance curve.
  • Who's Online   0 Members, 0 Anonymous, 369 Guests (See full list)
