Posted May 22, 200222 yr comment_7561 Anyone fitted Jaguar 2 inch SUs to their Datsun. I'm not sure what I have to change so that they run properly on my 260. I can modify the linkage fine but am not sure about needles.Thanks Link to comment https://www.classiczcars.com/forums/topic/1730-jaguar-sus/ Share on other sites More sharing options...
May 28, 200222 yr comment_7901 Dan Baldwin (I think) put some on his 3.1L IIRC, he wasn't overly impressed with them. You might catch him on the 240Z list. Link to comment https://www.classiczcars.com/forums/topic/1730-jaguar-sus/#findComment-7901 Share on other sites More sharing options...
June 24, 200222 yr comment_9357 Quote Dan Baldwin (I think) put some on his 3.1L IIRC, he wasn't overly impressed with them. You might catch him on the 240Z list. :stupid: Stupid Question but I'm a newby so go easy. What exactly is the 240Z List? Link to comment https://www.classiczcars.com/forums/topic/1730-jaguar-sus/#findComment-9357 Share on other sites More sharing options...
June 24, 200222 yr comment_9358 He might be referring to the mailing list... http://www.240z.org/mailman/listinfo/list Link to comment https://www.classiczcars.com/forums/topic/1730-jaguar-sus/#findComment-9358 Share on other sites More sharing options...
June 26, 200222 yr comment_9447 Not might, he is....MN Link to comment https://www.classiczcars.com/forums/topic/1730-jaguar-sus/#findComment-9447 Share on other sites More sharing options...
July 19, 200222 yr comment_10925 Better late than never, I hope. Actually, I've had pretty good success with the 2" Jag carbs. Noticeable improvement in top-end breathing on the 3.1. Prior to using the big carbs, I would kind of hit a wall at ~6000 in 4th (though the motor pulled to 7000 in the lower gears). This was really annoying at the faster tracks like Watkins Glen. With the big carbs the wall was softer and at more like 6500 rpm. With recent headwork and cam ($$$$), there is no more wall at all! The 2" SUs seem to be a good solution to high-rpm breathing on a big-inch carbureted L6. Link to comment https://www.classiczcars.com/forums/topic/1730-jaguar-sus/#findComment-10925 Share on other sites More sharing options...
