  • 4 weeks later...
  • 4 weeks later...
Better late than never, I hope. Actually, I've had pretty good success with the 2" Jag carbs. Noticeable improvement in top-end breathing on the 3.1. Prior to using the big carbs, I would kind of hit a wall at ~6000 in 4th (though the motor pulled to 7000 in the lower gears). This was really annoying at the faster tracks like Watkins Glen. With the big carbs the wall was softer and at more like 6500 rpm. With recent headwork and cam ($$$$), there is no more wall at all! The 2" SUs seem to be a good solution to high-rpm breathing on a big-inch carbureted L6.
https://www.classiczcars.com/forums/topic/1730-jaguar-sus/#findComment-10925
