Posted September 29, 200519 yr comment_139839 okay. im getting ready to put a full 260z head on my l28. the problem is that the mechanical fuel pump leaks fuel and oil. my question is can i use just the stock electric fuel pump? or do i need anything else.also, do they sell rebuild kits for the mechanical pump? Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/ Share on other sites More sharing options...
September 29, 200519 yr comment_139845 What are you doing ? If you are going to run carbs, you cannot use a fuel pump that is for injection. Too much pressure . I suppose you could use a pressure relief of some sort but if you just install a pump from a RX-7 Carbed car you will be fine . They put out about 5 psi. Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139845 Share on other sites More sharing options...
September 29, 200519 yr Author comment_139846 oh.. ill be using the carbs... im just wondering if the 260z electric fuel pump (they came with 2 pumps) will work? if not.. that rx-7 one sounds sweet. Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139846 Share on other sites More sharing options...
September 29, 200519 yr comment_139851 The 260 pump will do fine by it's self. Have you done the numbers ? since the longer stroke of the L-28 , what compression will you be running ? Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139851 Share on other sites More sharing options...
September 29, 200519 yr Author comment_139853 really? the 260 electric pump will be fine?! thats a camel off my back. hehe.i dont know the comp, but until i can get a flattop block, its an n42 with a 74 e88 w/ 72' carbs. Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139853 Share on other sites More sharing options...
September 29, 200519 yr comment_139918 i dont know the comp, but until i can get a flattop block, its an n42 with a 74 e88 w/ 72' carbs.now i know i'm infected with the Z virus, cause i actually understand this sentence.sorry to intrude,bart Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139918 Share on other sites More sharing options...
September 29, 200519 yr Author comment_139919 . thats great dude. Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139919 Share on other sites More sharing options...
September 29, 200519 yr comment_139920 28oZ . You can send a PM to phred , He mostlikely can give you an idea of the comp ratio . mlc240z sorry some times we do take it for granted that others can understand this stuff . Yes You are infected . Gary Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139920 Share on other sites More sharing options...
September 29, 200519 yr comment_139921 bean,no need to be sorry, i was tickled by the Zvirus 33 years ago and finally 'welcomed' the full blown infection in 11-04.bart Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139921 Share on other sites More sharing options...
September 30, 200519 yr comment_139929 http://www.ozdat.com/ozdatonline/enginedesign/Not hard to figure out compression (static).Dave Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139929 Share on other sites More sharing options...
September 30, 200519 yr comment_139930 Hey Ted. Look us up at centralfloridazclub@aol.com Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139930 Share on other sites More sharing options...
September 30, 200519 yr Author comment_139962 hey 1st gen Z. do you know anyone with a good efi round port head?where do you guys hang out? we gotta chill sometime. Link to comment https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/#findComment-139962 Share on other sites More sharing options...
