okay. im getting ready to put a full 260z head on my l28.
the problem is that the mechanical fuel pump leaks fuel and oil.
my question is can i use just the stock electric fuel pump? or do i need anything else.
also, do they sell rebuild kits for the mechanical pump?
https://www.classiczcars.com/forums/topic/17424-not-using-the-mech-fuel-pump/
What are you doing ? If you are going to run carbs, you cannot use a fuel pump that is for injection. Too much pressure . I suppose you could use a pressure relief of some sort but if you just install a pump from a RX-7 Carbed car you will be fine . They put out about 5 psi.
i dont know the comp, but until i can get a flattop block, its an n42 with a 74 e88 w/ 72' carbs.
now i know i'm infected with the Z virus, cause i actually understand this sentence.
sorry to intrude,
bart
28oZ . You can send a PM to phred , He mostlikely can give you an idea of the comp ratio . mlc240z sorry some times we do take it for granted that others can understand this stuff . LOL Yes You are infected . LOL Gary
