Posted September 30, 200519 yr comment_139964 i have read that the the RB30DET in 38 mm taller n i was wondering if it would cause any problems in a 240z , and if it does wat can i do to fix the problem thanks Link to comment https://www.classiczcars.com/forums/topic/17434-rb30det-bonnet-issues/ Share on other sites More sharing options...
September 30, 200519 yr comment_139965 Unless you have exceptionally low engine mounts I cant see any way around it, however a user here RB30-ZED i think, has done it using the OEM crossover plenum.My solution on mine was to use an aftermarket front facing plenum. Link to comment https://www.classiczcars.com/forums/topic/17434-rb30det-bonnet-issues/#findComment-139965 Share on other sites More sharing options...
September 30, 200519 yr comment_139968 Can be done without too much drama.need to modify sump anyway & with modified engine mounts (read totally re-engineered) & move engine back 50mm clearances can be achieved such that the RB30ET inlet plenum can still be used & it just clears the bonnet. Link to comment https://www.classiczcars.com/forums/topic/17434-rb30det-bonnet-issues/#findComment-139968 Share on other sites More sharing options...
April 22, 200618 yr comment_164604 It clears, but only just, this was using Drunkenmaster's engine mounts and a 20mm spacer sandwitched between the engine mounts and Drunkenmaster's RB engine mounts,Intially the mounts sat the engine to low, caused sump clearance issues with the RB20 rear sump, but still had decent hood clearance, as these mounts appear pretty much identical to Castle Maine Rod Shop RB/Z mounts, it might be an idea to use their RB rear mounted sump instead of the RB20 one, as it look as if its flat at the front of the sump, not sloping like the RB one,However, even with this additional spacer, the intake has about 5mm clearance before it hits the bonnet, so RB30's will easily fit under the hood :-), Link to comment https://www.classiczcars.com/forums/topic/17434-rb30det-bonnet-issues/#findComment-164604 Share on other sites More sharing options...
