What size Hard line for Injector Fuel Supply?
TomoHawk
I replaced the old rusted fuel injection rail with one from Pallnet, but I plumbed it with 1/4 inch steel brake line for the supply & return. I'm thinking that the injectors can't flow enough fuel to give the car real power like it should (starvation). It just doesn't push you back into your seat that much when you floor the pedal.
Should I replumb the fuel injection rail with 5/16 or 3/8 stainless? I would also used polished tubing, and maybe even compression fittings, but the pressure regulator and connections to the supply & return to the tank get 5/16 (7mm) rubber hose, which was oem.
thx.
  • 5 months later...
