Posted October 12, 200519 yr comment_141376 I'm gathering the parts to get rid of the injection on my 71 240Z (installed with the L28), and have a couple more questions:My carbs arrived today (4 screw round tops on an E88 manifold set). I'm going to need a heat shield. Will any heat shield ('70-74) work? Or do I need one that came with round tops?Also, I'm going to go to the local pick-n-pull to find an RX7 fuel pump. Anyone know where Mazda mounted these units? Underneath, near the tank, I assume? Link to comment https://www.classiczcars.com/forums/topic/17589-injection-out-sus-in/ Share on other sites More sharing options...
October 12, 200519 yr comment_141382 I think the early heat shield will work . The fuel pump is located on the driver's side and just infront of the rear axel . Gary Link to comment https://www.classiczcars.com/forums/topic/17589-injection-out-sus-in/#findComment-141382 Share on other sites More sharing options...
October 12, 200519 yr comment_141385 any of the 3 designed for 240Zs will work, but if you get one of the 2 with provision for the heat riser, you must use a heat riser designed for the specific heat shield you get. IOW you can't mix heat risers and heat shields and expect them to fit together. Link to comment https://www.classiczcars.com/forums/topic/17589-injection-out-sus-in/#findComment-141385 Share on other sites More sharing options...
October 12, 200519 yr Author comment_141387 Thanks to you both. As for the heat riser, I won't be using one at all, since I will still have the cast exhaust manifold from the ZX on it for the foreseeable future. One thing at a time. Link to comment https://www.classiczcars.com/forums/topic/17589-injection-out-sus-in/#findComment-141387 Share on other sites More sharing options...
