October 18, 200519 yr comment_142230 Does MSA even deal in used parts? I know some parts are rebuilt/refurbished, but I don't recall ever seeing a section for ordering used parts.MSA does occasionally have used parts to choose from, if they have an overstock of parts that are already refurbed, the will sometimes just try to sell off the used parts.The only real way to get used parts from MSA is to call them and ask for something used. They'll have to check inventory.Chances are the hood is a refurb or new piece made specifically for MSA, like the louvered hood they sell.Back to the original post - Get the order number/invoice and call MSA. Otherwise you're sitting around wondering until the box shows up on the truck. Link to comment https://www.classiczcars.com/forums/topic/17622-240z-nos-hood/?&page=2#findComment-142230 Share on other sites More sharing options...
October 18, 200519 yr comment_142231 I'd rather have a really good used original hood than get stuck with some cheap aftermarket part.agreed...some of those aftermarkets are like pressed tin foil... Link to comment https://www.classiczcars.com/forums/topic/17622-240z-nos-hood/?&page=2#findComment-142231 Share on other sites More sharing options...
October 18, 200519 yr comment_142235 I doubt that MSA would send a used part without the customer (in this case your "resto" shop) indicating a willingness to accept such a part. Link to comment https://www.classiczcars.com/forums/topic/17622-240z-nos-hood/?&page=2#findComment-142235 Share on other sites More sharing options...
October 21, 200519 yr Author comment_142537 My resto shop told me that it must be perfect and will not put something that will not be acceptable.It is an interesting discussion because of the opinions about NOS (or reproduction) versus good used one.This question must appear silly for many of you but I am not a body expert. If the hood to come is silver and the car's original paint is orange, it makes sense that the used hood will have to be stripped both sides to bare metal?What will happen to the unacessible ereas as the underside framing of the hood to remove and seal the metal and repaint the right color?Maybe I worry to much on the subject.Anyway, thanks to everybody for your comments. Link to comment https://www.classiczcars.com/forums/topic/17622-240z-nos-hood/?&page=2#findComment-142537 Share on other sites More sharing options...
October 21, 200519 yr comment_142540 I've been through this before with an earlier restoration. A few additional thoughts:Even a brand new original Nissan part (either NOS or current, if still available) will most likely still need minor finish work prior to painting. When Datsun built the car, the hood was pressed and assembled quite close to the final assembly line. Not so for a replacement part - it has been shipped from Japan on a boat, and then transported by truck at least twice, perhaps several times. No way it is going to arrive as pristine as when it was packaged in Japan, it's going to have small nicks and dimples at best, and could even have gotten slightly twisted somewhere along the way.A really good used one will have a lot shorter trip to you than the new one, and MSA will probably package it as well or better than Nissan would.Any good restoration shop will know where and how to get all the paint stripped from a used body part. They will also know how to prime and seal it prior to painting it.I guess my advice would be to express your concerns to your repair shop, and then trust them if they are comfortable with the part they receive. Link to comment https://www.classiczcars.com/forums/topic/17622-240z-nos-hood/?&page=2#findComment-142540 Share on other sites More sharing options...
October 21, 200519 yr Author comment_142543 Thank you Arne to light up my ignorance on the subject.I am finally convinced that a nice used one could be better and wipe out my concern. Link to comment https://www.classiczcars.com/forums/topic/17622-240z-nos-hood/?&page=2#findComment-142543 Share on other sites More sharing options...
